Nyloc front stub axle bearing nut
Front stub axle bearing nut 1A 4019 is an Austin special size 5/8 inch 16 tpi. Whitworth form (55 degree thread angle).
Has anyone found and used a Nyloc that size??
Just thinking to try and avoid tedium of finding/filingĀ a shim washer to get castellation in line with hole for split pin without having nut over/under tightened.
Dennis
