Nyloc front stub axle bearing nut - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Nyloc front stub axle bearing nut (/showthread.php?tid=7218) |
Nyloc front stub axle bearing nut - Dennis Nicholas - 25-02-2022 Front stub axle bearing nut 1A 4019 is an Austin special size 5/8 inch 16 tpi. Whitworth form (55 degree thread angle). Has anyone found and used a Nyloc that size?? Just thinking to try and avoid tedium of finding/filingĀ a shim washer to get castellation in line with hole for split pin without having nut over/under tightened. Dennis |
