Tapered pins clutch release shaft
Can anyone advise me of the SECRET to removing the tapered pins from the clutch release shaft on the transmission. I need to replace the arms. Any help would be appreciated.  Arnie
Found the SECRET. Drive from the correct side. All I was doing was tightening. At 78 years old you would have thought I would know better
Glad you succeeded - it can be a horrible job.
