Tapered pins clutch release shaft - Printable Version
+--- Thread: Tapered pins clutch release shaft (/showthread.php?tid=6360)
Tapered pins clutch release shaft - SneezerUSA - 09-07-2021
Can anyone advise me of the SECRET to removing the tapered pins from the clutch release shaft on the transmission. I need to replace the arms. Any help would be appreciated.  Arnie
RE: Tapered pins clutch release shaft - SneezerUSA - 09-07-2021
Found the SECRET. Drive from the correct side. All I was doing was tightening. At 78 years old you would have thought I would know better
RE: Tapered pins clutch release shaft - Chris KC - 10-07-2021
Glad you succeeded - it can be a horrible job.
