25-05-2021, 03:32 AM
Can anyone tell me if the pin securing the gear to the spindle of a DK-4A distributor is straight or tapered?
Dizzy gear pin
25-05-2021, 08:01 AM
Hi Peter
I’ve used a straight pin peened over at each end. I don’t think (Hope ) that the hole is tapered. Cheers Howard
25-05-2021, 10:42 AM
Use an 1/8" rollpin some replacement gears have a 4mm hole for Bosch distributors, a rollpin is a more secure fixing. Terry.
25-05-2021, 01:24 PM
25-05-2021, 04:00 PM
I agree a rollpin is the way forward
25-05-2021, 04:46 PM
28-05-2021, 06:41 AM
Ha! No one sells Imperial roll pins in Townsville except a large engineering supply company but I really do not want to buy a roll pin kit with 1,200 variously sized pins. Looks like it will have to be a piece of 1/8" mild steel (welding rod?) riveted. Thank you for your replies.
28-05-2021, 08:18 AM
Peter, not sure I should raise my head up over the parapet here but.......
Same situation, I need to change the bottom disty shaft, the one with the helical gears on my DJ4A. Lucas says use a 1/8 “ pin. I did not have one and the UK is a couple of weeks away from me in NZ. So I rustled about in my nail collection and found a galvanised nail slightly over size but a bit of coarse emery cloth reduced it to fit. Firm fit and then peen or centre punch each end. I did find that the hole going through the disty part didn’t line up with the hole in the new bottom shaft. Turned it around 180 and all was good. Not a lot of precision accuracy back in the day. Cheers Gary Auckland0
28-05-2021, 08:48 AM
Probably individually fitted as the picture."Handcrafted" or individually hand fitted and still much revered in some circles.
