Dizzy gear pin - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Dizzy gear pin (/showthread.php?tid=6162) Pages:
1
2
Dizzy gear pin - Peter Arnold - 25-05-2021 Can anyone tell me if the pin securing the gear to the spindle of a DK-4A distributor is straight or tapered? RE: Dizzy gear pin - Howard Wright - 25-05-2021 Hi Peter I’ve used a straight pin peened over at each end. I don’t think (Hope ) that the hole is tapered. Cheers Howard RE: Dizzy gear pin - John Cornforth - 25-05-2021 Hi Peter I think it's plain 1/8 th inch. See Lucas picture. RE: Dizzy gear pin - Terrytuned - 25-05-2021 Use an 1/8" rollpin some replacement gears have a 4mm hole for Bosch distributors, a rollpin is a more secure fixing. Terry. RE: Dizzy gear pin - Ian McGowan - 25-05-2021 (25-05-2021, 10:42 AM)Terrytuned Wrote: Use an 1/8" rollpin some replacement gears have a 4mm hole for Bosch distributors, a rollpin is a more secure fixing. Terry. + 1 RE: Dizzy gear pin - Nick Turley - 25-05-2021 I agree a rollpin is the way forward RE: Dizzy gear pin - Ruairidh Dunford - 25-05-2021 (25-05-2021, 10:42 AM)Terrytuned Wrote: Use an 1/8" rollpin some replacement gears have a 4mm hole for Bosch distributors, a rollpin is a more secure fixing. Terry. I agree, use a suitable rollpin. RE: Dizzy gear pin - Peter Arnold - 28-05-2021 Ha! No one sells Imperial roll pins in Townsville except a large engineering supply company but I really do not want to buy a roll pin kit with 1,200 variously sized pins. Looks like it will have to be a piece of 1/8" mild steel (welding rod?) riveted. Thank you for your replies. RE: Dizzy gear pin - GaryCullen - 28-05-2021 Peter, not sure I should raise my head up over the parapet here but....... Same situation, I need to change the bottom disty shaft, the one with the helical gears on my DJ4A. Lucas says use a 1/8 “ pin. I did not have one and the UK is a couple of weeks away from me in NZ. So I rustled about in my nail collection and found a galvanised nail slightly over size but a bit of coarse emery cloth reduced it to fit. Firm fit and then peen or centre punch each end. I did find that the hole going through the disty part didn’t line up with the hole in the new bottom shaft. Turned it around 180 and all was good. Not a lot of precision accuracy back in the day. Cheers Gary Auckland0 RE: Dizzy gear pin - Bob Culver - 28-05-2021 Probably individually fitted as the picture."Handcrafted" or individually hand fitted and still much revered in some circles. |
