27-04-2021, 12:37 AM
Are the symptoms the same for first? Are they worse when box oil is hot? Let's not discount dragging clutch, pedal travel against the floor or crank case stop, worn fingers etc. If no syncro on 2nd are you skilled in ddc ? There are remedies . Simple things first before removing the box.
