Main bearing advice
Hi all
Starting to rebuild my new engine and need to purchase new main bearings.. Trouble is I'm not sure which ones I need for the front. The crankcase number is 186772, should I be getting the AC full width or the AC narrow set? Looking at the details on our cherished suppliers sites the cutover seems to be 1934 which I think is about the age of my crankcase....
Any advice very gratefully received
Robbie
(23-01-2018, 11:29 PM)Robbie.watson@uk.bp.com Wrote: Hi all
Robbie
For a while the narrow bearings were fitted in the old housings with two 30 thou spacing washers front and back.
Measure the housing depth- the pair of standard 'wide' bearing are 1 5/8" the pair of  'narrow' outer ring bearings are 1 9/16" (approx 60 thou less).
Cheers, Tony.
Cheers, Tony.
Thanks Tony, just what I need. I'll measure tomorrow and then order  Smile
