18-02-2021, 04:14 PM
(This post was last modified: 18-02-2021, 04:17 PM by Jacob Fowkes.)
Accu spark
18-02-2021, 05:01 PM
I have always used the normal copper cored HT lead with mine - no issues.
18-02-2021, 05:12 PM
Agreed , I may go back to them as this seems an un needed modification. Thanks
18-02-2021, 07:34 PM
I have been using the carbon cores leads for a few years without any problems. What issues are you having?
It is weird stuff and I was worried that the core might snap, but touch wood it has been ok. Peter
18-02-2021, 08:01 PM
I may be getting something wrong but I can’t seem to get a spark. Would you be able to tell me now you connected the little copper contacts to the ends of the wires. Cheers
18-02-2021, 08:16 PM
Have you measured the resistance in the leads to check there is no break in the core?
18-02-2021, 08:31 PM
Powerspark suggest only carbon core leads for there system, I've yet to fit mine but warmer weather may help me get into the garage soon.
18-02-2021, 08:44 PM
(This post was last modified: 18-02-2021, 08:46 PM by Jacob Fowkes.
Edit Reason: Spell
Hi Paul yes I have so I think the cores are good. I’m more puzzled by how you attach the little washer type contacts. I’ve seen crimp on ones where a little spike is pushed in the core. I’ve also seen a photo where you push the fibres through the washer (photo attached) I tried this and no spark.
1736FB9D-5479-4F36-B9E3-C75CA07446BF.jpeg (Size: 29.73 KB / Downloads: 284) The unit looks really well made but the instructions are most useful for lighting a fire to keep warm at this time of year. I think this photo is for the copper core. Also the coil is new and works
18-02-2021, 10:08 PM
Carbon leads don't really work with the little washer - I found out when using mismatched components on an old Mini. They often have the core tightly trapped under a metal collar to provide the necessary contact.
I'm not sure how Accuspark intended them to fit together.
18-02-2021, 10:29 PM
Cheers I have no idea how they intend for you to fit them.
