Accu spark - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Accu spark (/showthread.php?tid=5695) |
Accu spark - Jacob Fowkes - 18-02-2021 hi guys has anyone had any trouble with the accuspark ht leads as I’m struggling with mine I think they’re the fancy carbon core stuff RE: Accu spark - Ruairidh Dunford - 18-02-2021 I have always used the normal copper cored HT lead with mine - no issues. RE: Accu spark - Jacob Fowkes - 18-02-2021 Agreed , I may go back to them as this seems an un needed modification. Thanks RE: Accu spark - Peter Johnson - 18-02-2021 I have been using the carbon cores leads for a few years without any problems. What issues are you having? It is weird stuff and I was worried that the core might snap, but touch wood it has been ok. Peter RE: Accu spark - Jacob Fowkes - 18-02-2021 I may be getting something wrong but I can’t seem to get a spark. Would you be able to tell me now you connected the little copper contacts to the ends of the wires. Cheers RE: Accu spark - Paul N-M - 18-02-2021 Have you measured the resistance in the leads to check there is no break in the core? RE: Accu spark - flywheel1935 - 18-02-2021 Powerspark suggest only carbon core leads for there system, I've yet to fit mine but warmer weather may help me get into the garage soon. RE: Accu spark - Jacob Fowkes - 18-02-2021 Hi Paul yes I have so I think the cores are good. I’m more puzzled by how you attach the little washer type contacts. I’ve seen crimp on ones where a little spike is pushed in the core. I’ve also seen a photo where you push the fibres through the washer (photo attached) I tried this and no spark. 1736FB9D-5479-4F36-B9E3-C75CA07446BF.jpeg (Size: 29.73 KB / Downloads: 284) The unit looks really well made but the instructions are most useful for lighting a fire to keep warm at this time of year. I think this photo is for the copper core. Also the coil is new and works RE: Accu spark - Peter Naulls - 18-02-2021 Carbon leads don't really work with the little washer - I found out when using mismatched components on an old Mini. They often have the core tightly trapped under a metal collar to provide the necessary contact. I'm not sure how Accuspark intended them to fit together. RE: Accu spark - Jacob Fowkes - 18-02-2021 Cheers I have no idea how they intend for you to fit them. |
