Hole on bell housing
Video
Could anyone enlighten me as to what should go here as there just seems to be a large threaded hole on the bottom of the bell housing that you can reach right into and feel the clutch?
Bear in mind this is a Big Seven.
It's an access/oil drain hole. The bit of tube has been added, should be covered by a plain plate, secured by two 1/4 BSF screws.
