Hole on bell housing - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Hole on bell housing (/showthread.php?tid=5272) |
Hole on bell housing - 12jslater - 18-11-2020 Could anyone enlighten me as to what should go here as there just seems to be a large threaded hole on the bottom of the bell housing that you can reach right into and feel the clutch? RE: Hole on bell housing - Jeff Taylor - 19-11-2020 Bear in mind this is a Big Seven. RE: Hole on bell housing - Parazine - 20-11-2020 It's an access/oil drain hole. The bit of tube has been added, should be covered by a plain plate, secured by two 1/4 BSF screws. |
