Diff carrier bearings
Hi All
I’m rebuilding the axle in my RK.  The diff carrier bearings on the axle are SKF RLS 10 , (withMTLD stamped on the inner race).
I don’t think these are angular contact thrust bearings.  Can anyone confirm?
Howard, that number is for ordinary ball bearings, not AC.
Gene
Thanks Gene
I thought that but good to have it confirmed  Smile.
I think the bearings you have are correct for 1923-28 axles (also known as LJ 1 1'/4") - shim adjusted side tube.
Hi Ruairidh
Thanks I know the RK needs angular contacts. I guess the previous owner might have either got the wrong info or couldn’t afford the right bearings!
Never mind I can use them in the hubs  Big Grin.
You can indeed!
I wonder how long been used? Tony Press can provide relative thrust ratings. ""Modern"" bearings are rated much higher than in 1920s. For moderate use maybe just turn around and reuse!
