25-05-2020, 08:48 AM
The Benjamin horn on my 12 volt Chummy works well but I worry that it won't last. Is there some way that I can help it, explained in simple terms?
Benjamin
25-05-2020, 10:05 AM
Convert your chummy back to 6V and the whole thing will be more happy
25-05-2020, 10:40 AM
All you need to do is fit a resistor in line.
25-05-2020, 11:26 AM
25-05-2020, 12:30 PM
My RL saloon has a Benjamin horn that came out of a farmers outbuilding. It was given to me in the late 1980's. I brushed the rust off it and opened it up, the inside was quite good and when I connected up a 12 volt battery, it worked fine. I duly fitted it to the saloon in 1998 and it has been working well ever since on 12 volts. in my part of the world it gets used quite a lot. I have never worried about it wearing out. Presumably on 6 volts it will not be so strident!
26-05-2020, 10:00 AM
I found that the Benjamin horn worked OK on 12 volts whilst the Rist horn didn't like it. My solution was to fit a dynamo field resistor in series with the horn. However I found that modern car drivers couldn't hear my Rist horn so I replaced it with the twin air horns father had on his Rover 2000, they hear that.
27-05-2020, 10:08 AM
Thanks everyone, Benjamin and I are now happy.
Dave, I have a very loud Klaxon horn which would be more in keeping, if there was space under the bonnet to conceal it
27-05-2020, 10:31 AM
My RP saloon has its original Rists horn. Unkind people say it sounds like a duck!
27-05-2020, 10:50 AM
My RF Rists horn wouldn't frighten a duck.
27-05-2020, 11:06 AM
As people stand and stare - and smile broadly - as you drive past in your Seven, a toot on the Rist or Benjamin only adds to the entertainment. Some expensive cars used to have a "town and country" setting for their horns - gentlemanly progress thus assured. Horn stories? I had a Citroen AX Diesel whose horn was a miserable, pipi-squeak affair; I replaced it with a pair of loud and stately-sounding two-tone jobs from a retired Triumph 2000; the amusing thing was, that when used, everyone looked around for a bigger and more stately carriage.
