12-04-2020, 06:17 PM
rev counter drive
12-04-2020, 06:36 PM
I have a feeling Tony Betts (Seven County Austins) used to do these.
Don't mean to criticise but I have a worry about that grease nipple - lubrication in this area wants to be done very sparingly.
12-04-2020, 06:53 PM
Hi Oliver
I made my own. The main difficulty was getting a threaded rod to match the cable nut. As it happened the nut on the cable I bought was very weak alloy and I ended up making a new one so could have used any thread. Here’s a pic. Of the components and finished drive. I echo Chris’s comments on lubrication! Luckily I have original oilers on my two cars. Cheers Howard
12-04-2020, 07:22 PM
I think Dave Dye does these.
Erich in Seattle
13-04-2020, 05:08 PM
I use the threaded speedo drive from the 4 speed gearbox , rather like Howard does with a thin nut in the bottom of the dynamo. The drive is a spade drive from a Vincent motorbike, available on the internet. All it needs is a slot with a double hacksaw in the distributor drive after you remove the drive gear. I will take some pictures tomorrow.
14-04-2020, 05:23 PM
Rev drive.docx (Size: 611.58 KB / Downloads: 116)
16-04-2020, 12:47 PM
I have a lovely Speedex rev counter for my special but no drive from the dynamo, I don't feel confident to do the modification myself would anyone know of someone who would take the job on the me. I do have the cable with a 90 degree drive.
16-04-2020, 01:43 PM
(This post was last modified: 16-04-2020, 01:45 PM by Austin in the Shed.
Edit Reason: add content
I can still do these but require the dynamo end and distributor shaft to do it.The dynamo end needs to be drilled and faced in the lathe to do a good job.The drive cable is likely to fail quickly if not.
I can make the drive the same as the gearbox output. Pm me if so. Is your rev counter 2:1,will it run both ways ? |
