rev counter drive - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: rev counter drive (/showthread.php?tid=4183) |
rev counter drive - mopetta - 12-04-2020 On my A7, I have this rev counter drive mounted at the dynamo. Inside, it uses a speedo cable drive pinion to attach the cable. I would like to find something similar for my second A7. Is such a rev counter drive available somewhere or do I have to make one myself ? thanks, Oliver RE: rev counter drive - Chris KC - 12-04-2020 I have a feeling Tony Betts (Seven County Austins) used to do these. Don't mean to criticise but I have a worry about that grease nipple - lubrication in this area wants to be done very sparingly. RE: rev counter drive - Howard Wright - 12-04-2020 Hi Oliver I made my own. The main difficulty was getting a threaded rod to match the cable nut. As it happened the nut on the cable I bought was very weak alloy and I ended up making a new one so could have used any thread. Here’s a pic. Of the components and finished drive. I echo Chris’s comments on lubrication! Luckily I have original oilers on my two cars. Cheers Howard RE: rev counter drive - Erich - 12-04-2020 I think Dave Dye does these. Erich in Seattle RE: rev counter drive - Lowespeed - 13-04-2020 I use the threaded speedo drive from the 4 speed gearbox , rather like Howard does with a thin nut in the bottom of the dynamo. The drive is a spade drive from a Vincent motorbike, available on the internet. All it needs is a slot with a double hacksaw in the distributor drive after you remove the drive gear. I will take some pictures tomorrow. RE: rev counter drive - Lowespeed - 14-04-2020 ![]() RE: rev counter drive - Gem4373 - 16-04-2020 I have a lovely Speedex rev counter for my special but no drive from the dynamo, I don't feel confident to do the modification myself would anyone know of someone who would take the job on the me. I do have the cable with a 90 degree drive. RE: rev counter drive - Austin in the Shed - 16-04-2020 I can still do these but require the dynamo end and distributor shaft to do it.The dynamo end needs to be drilled and faced in the lathe to do a good job.The drive cable is likely to fail quickly if not. I can make the drive the same as the gearbox output. Pm me if so. Is your rev counter 2:1,will it run both ways ? |
