15-03-2020, 12:49 PM
https://www.ebay.co.uk/itm/174220360342?ul_noapp=true
Looks basically similar yet different... what is that off?
odd sports axle...
15-03-2020, 01:13 PM
It looks like the axle ends have been welded on to the 'H' section?
15-03-2020, 01:36 PM
(This post was last modified: 15-03-2020, 01:41 PM by dickie65.
Edit Reason: more info
Ha Ha,
Some one is trying to up the price !! Its a Very Rusty Big Seven front axle. It could possible be from a ford though, the brake actuator looks non Austin. ( Note the Girling Brakes ) not early at all. A few folks have used them on Sevens the king pins are 5/8" and the track rod goes in front of the axle.
15-03-2020, 01:37 PM
(This post was last modified: 15-03-2020, 01:39 PM by Nick Lettington.)
Is it not a big 7 axle then?
Ah... simultaneously responding... rhetorical question!
15-03-2020, 01:40 PM
(This post was last modified: 15-03-2020, 01:44 PM by squeak.
I believe it to be a standard big seven axle. Another one is for sale on Ebay
https://www.ebay.co.uk/sch/i.html?_from=...6&_sacat=0
15-03-2020, 04:44 PM
Big Seven all day long!
Good for non vintage specials/racers. Wider track, stronger, bigger king pins. The forward track control arms can be reversed to face backwards if new keyways are machined into them. Paul N-M
15-03-2020, 08:16 PM
Yes, Big Seven.
15-03-2020, 10:50 PM
I have one exactly the same from a big 7.
