Inline fuel filter
Hi all, I am considering fitting an in-line fuel filter to my Ruby. All the filters I have found are for plastic/rubber petrol pipe as are fitted to moderns. Does anybody know of a source where I can get one with connections to copper fuel pipe.
John Mason.
https://www.vintagecarparts.co.uk/catego...uel-system
Hi John
I picked up one at Beaulieu a couple years ago.  I think it was on one of the many motorcycle orientated stalls. I think I paid a tenner for it!
On a Ruby you should have a fine filter in the fuel pump and another within the carb banjo fitting. This should be adequate .
Derek, You are correct in what you say but something keeps clogging up my carb jets. I will investigate further.
John Mason
I have not been able to find filters for the "Banjo" pipe to carb union for the 30VE1 nor FZB22 nor 24T2 (does it have one?? I cannot recall!) I have fitted a modern in line filter on the 1928 AD with it's 24T2 carb- it was sensitive to angle - and pre war motor cycle type filters to the other two.
I can see using in line filter in gravity fed systems , have fitted a glass bowl type ad shown above in my Chummy. I don’t know if the banjo filters are available but I make my own, can supply a few at a fiver a pop.! They were 6d each in 1937 which I think you will find equates to somewhere near a fiver today.
Very neat engine bay Howard
Thanks David
Smile
