Inline fuel filter - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Inline fuel filter (/showthread.php?tid=3866) |
Inline fuel filter - John Mason - 05-02-2020 Hi all, I am considering fitting an in-line fuel filter to my Ruby. All the filters I have found are for plastic/rubber petrol pipe as are fitted to moderns. Does anybody know of a source where I can get one with connections to copper fuel pipe. John Mason. RE: Inline fuel filter - Chris KC - 05-02-2020 https://www.vintagecarparts.co.uk/categories/vintage-car-parts-fuel-system RE: Inline fuel filter - Howard Wright - 05-02-2020 Hi John I picked up one at Beaulieu a couple years ago. I think it was on one of the many motorcycle orientated stalls. I think I paid a tenner for it! Cheers Howard RE: Inline fuel filter - Derek Sheldon - 06-02-2020 On a Ruby you should have a fine filter in the fuel pump and another within the carb banjo fitting. This should be adequate . RE: Inline fuel filter - John Mason - 06-02-2020 Derek, You are correct in what you say but something keeps clogging up my carb jets. I will investigate further. John Mason RE: Inline fuel filter - David.H - 06-02-2020 I have not been able to find filters for the "Banjo" pipe to carb union for the 30VE1 nor FZB22 nor 24T2 (does it have one?? I cannot recall!) I have fitted a modern in line filter on the 1928 AD with it's 24T2 carb- it was sensitive to angle - and pre war motor cycle type filters to the other two. RE: Inline fuel filter - Derek Sheldon - 06-02-2020 I can see using in line filter in gravity fed systems , have fitted a glass bowl type ad shown above in my Chummy. I don’t know if the banjo filters are available but I make my own, can supply a few at a fiver a pop.! They were 6d each in 1937 which I think you will find equates to somewhere near a fiver today. RE: Inline fuel filter - David Witton - 06-02-2020 Very neat engine bay Howard RE: Inline fuel filter - Howard Wright - 07-02-2020 Thanks David ![]() Cheers Howard |
