Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
You won’t get the 3D effect by clamping as you suggest. Don’t know if that would make a difference. If you have such a problem soldering it , send it to me , I’ll do it for you.
Hi All
Bakers flux is what I use but I have a quite big electric soldering iron which is quite adequate for soldering the gauze. I do belt and braces and use flux cored solder. I also solder all the edges which as Chris points out ensures no bits of gauze get loose.
For bigger jobs like repairs to my fuel tank (suitably purged) or oil and fuel pipe unions I find a heat gun invaluable.
Car type:
ok, so looking at the frame, which is the best side of the holes to join? i.e. is it perfectly acceptable to solder on the inner side of the frame so there is less perimeter of gauze/solder and a smaller gauze overall? Or does the gauze being physically held by the set screws offer some additional safety?
I noticed when disassembling that it is quite possible to leave the original solder positions where they are and just detach the old gauze. (Not so easy on the bit round the edge). Presumably this makes it easier to add a bit of solder to the existing positions and then add the gauze, rather than re-tinning everything?
My soldering was not nearly that precise Jon - I just went all the way round trying to ensure it was stuck fast with no loose, fraying edge strands. I did not rely on screws to hold the mesh in the frame.
Just a random thought - Could you ignore soldering and simply sandwich a gauze between two carrier frames?
04-12-2019, 04:13 PM
(This post was last modified: 04-12-2019, 04:27 PM by Derek Sheldon.)
Yes the old points are good enough to use but still thoroughly clean it. Spotting the hole areas will stop the mesh from fraying, either drill or punch the holes after. I also stop the edges from fraying by soldering the warp and weft ( up and down- left and right) on the very edges.
A
quick sample
