  • 1 Vote(s) - 3 Average
Zenith Fuel level
Hi,
I am in need of altering the fuel level on my zenith carb as it was leaking fuel when on a hill (not good for trailing). Does any one have any tips and what should the level be
Thanks
Hi
Might help if we knew which model of Zenith?
On a 22FZ it should be 3mm below the jet level.  Yes all Zenith carb measurements seem to be metric!). Not a straightforward task to accomplish and definitely one with the carb off the car.
He Hi sorry yes it’s a 22fz. How is best to measure the level.
Hi Again
If you put “updraft carb float level” in the little Search box above all will be revealed.  I may have misled you in the last post the fluid level should be 1mm below the main jet.
This should show you how to do it.
Thanks for all the useful reply's.
I will give it a go
