Zenith Fuel level - Printable Version
+--- Thread: Zenith Fuel level (/showthread.php?tid=3419)
Zenith Fuel level - leaf200 - 16-10-2019
Hi,
I am in need of altering the fuel level on my zenith carb as it was leaking fuel when on a hill (not good for trailing). Does any one have any tips and what should the level be
Thanks
RE: Zenith Fuel level - Howard Wright - 16-10-2019
Hi
Might help if we knew which model of Zenith?
On a 22FZ it should be 3mm below the jet level.  Yes all Zenith carb measurements seem to be metric!). Not a straightforward task to accomplish and definitely one with the carb off the car.
RE: Zenith Fuel level - leaf200 - 16-10-2019
He Hi sorry yes it’s a 22fz. How is best to measure the level.
Hi Again
If you put “updraft carb float level” in the little Search box above all will be revealed.  I may have misled you in the last post the fluid level should be 1mm below the main jet.
RE: Zenith Fuel level - Ian McGowan - 16-10-2019
This should show you how to do it.
RE: Zenith Fuel level - leaf200 - 17-10-2019
Thanks for all the useful reply's.
I will give it a go
