Condenser and points for 12 volt
I've just started getting a problem with my electronic distributer.....haven't had time to take it out and have a good look but a quick road side visual indicated that the rotor position could move back and forth between adv and retd
without any spring tension.
The car is 12 volt, can I fit the standard distributer with the points and condenser that would normally be used with 6 volt  ? or do I need to change anything ?
Thanks
The points distributor will work fine on 12V without any mods.
Thanks Stuart
I will dig out the old distributer and give it a go
Check the state of the drive gears when you take off the electronic one.
