15-08-2019, 09:45 AM
(This post was last modified: 15-08-2019, 09:45 AM by Jamie.)
Good morning.
I need to replace the nuts which secure the studs attaching the alloy links to the front damper arms. Does anyone know what thread size they are, please?
Thank you.
Jamie.
Look like 3/8" BSF.
Regards,
Colin
Off hand I dunno about the particular stud, but some nuts on s.as are cycle thread. The tpi can be counted. Care necessary not to mix (or lose). The threads were contd on Asian bikes for a long time byt dunno about latest.
The Cycle threads are only on the tension bolt which goes trough the centre of the Damper, it is not found at the shackle end, is very obviously fine pitched and shouldn't easily be confused.
Thank you, Colin, for the size.
Kind regards,
Jamie.
