Front Damper Link Stud Thread Size - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Front Damper Link Stud Thread Size (/showthread.php?tid=3207) |
Front Damper Link Stud Thread Size - Jamie - 15-08-2019 Good morning. I need to replace the nuts which secure the studs attaching the alloy links to the front damper arms. Does anyone know what thread size they are, please? Thank you. Jamie. RE: Front Damper Link Stud Thread Size - Colin Morgan - 15-08-2019 Look like 3/8" BSF. Regards, Colin RE: Front Damper Link Stud Thread Size - Bob Culver - 15-08-2019 Off hand I dunno about the particular stud, but some nuts on s.as are cycle thread. The tpi can be counted. Care necessary not to mix (or lose). The threads were contd on Asian bikes for a long time byt dunno about latest. RE: Front Damper Link Stud Thread Size - Ian Williams - 15-08-2019 The Cycle threads are only on the tension bolt which goes trough the centre of the Damper, it is not found at the shackle end, is very obviously fine pitched and shouldn't easily be confused. RE: Front Damper Link Stud Thread Size - Jamie - 15-08-2019 Thank you, Colin, for the size. Kind regards, Jamie. |
