02-11-2017, 12:05 PM
Does anyone know what size the bore of a pinchbolt steering wheel is? I only have one and I don't want to take it off yet.
Thanks
Alan
Thanks
Alan
Pinchbolt Steering Wheel
Thanks Alan
02-11-2017, 08:34 PM
Ian believes correctly - they are 7/8"
02-11-2017, 10:43 PM
Be careful with these - they can break around the area where the bolt goes through.
David
02-11-2017, 11:06 PM
Yes I agree David I have seen a few broken, I believe it is where the wheel has worked loose and over time enlarged the hole on the boss, owners then in a vain attempt to cure the problem over tighten the clamping bolt resulting in the boss cracking. Welding, sleeving, and re-machining are solution's, what other ingenious fixes have other's come up with
02-11-2017, 11:20 PM
I had to repair my steering on a campsite in the Picos mountains two summers ago - the wheel had begun to slide slightly on full lock and I initially thought the box had a serious problem.
Once I discovered the cause was actually the clamp bolt slot in the top of the steering column too enlarged (not the steering wheel), I resolved the issue by drinking a can of ice cold beer (it was 39°c) and then used it to make a shim around the centre of the bolt. It has held tight ever since.
Thanks, plan is to modify a later column to use a dished wheel. Will consider tinned beer - how many cans does it need?
02-11-2017, 11:26 PM
How long is a piece of string!
02-11-2017, 11:38 PM
02-11-2017, 11:43 PM
Sounds perfect - if I leave now I should be in time for an early breakfast, leave the porch light on.
