Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(287) : eval()'d code PHP 8.1.30 (Linux)
Pinchbolt Steering Wheel - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Pinchbolt Steering Wheel (/showthread.php?tid=403) Pages:
1
2
Pinchbolt Steering Wheel - Alan - 02-11-2017 Does anyone know what size the bore of a pinchbolt steering wheel is? I only have one and I don't want to take it off yet. Thanks Alan RE: Pinchbolt Steering Wheel - Ian Williams - 02-11-2017 7/8" I believe Alan RE: Pinchbolt Steering Wheel - Ruairidh Dunford - 02-11-2017 Ian believes correctly - they are 7/8" RE: Pinchbolt Steering Wheel - David Cochrane - 02-11-2017 Be careful with these - they can break around the area where the bolt goes through. David RE: Pinchbolt Steering Wheel - Ian Williams - 02-11-2017 Yes I agree David I have seen a few broken, I believe it is where the wheel has worked loose and over time enlarged the hole on the boss, owners then in a vain attempt to cure the problem over tighten the clamping bolt resulting in the boss cracking. Welding, sleeving, and re-machining are solution's, what other ingenious fixes have other's come up with RE: Pinchbolt Steering Wheel - Ruairidh Dunford - 02-11-2017 I had to repair my steering on a campsite in the Picos mountains two summers ago - the wheel had begun to slide slightly on full lock and I initially thought the box had a serious problem. Once I discovered the cause was actually the clamp bolt slot in the top of the steering column too enlarged (not the steering wheel), I resolved the issue by drinking a can of ice cold beer (it was 39°c) and then used it to make a shim around the centre of the bolt. It has held tight ever since. RE: Pinchbolt Steering Wheel - Alan - 02-11-2017 Thanks, plan is to modify a later column to use a dished wheel. Will consider tinned beer - how many cans does it need? RE: Pinchbolt Steering Wheel - Ruairidh Dunford - 02-11-2017 How long is a piece of string! RE: Pinchbolt Steering Wheel - Alan - 02-11-2017 (02-11-2017, 11:26 PM)Ruairidh Dunford Wrote: How long is a piece of string! 3 or 4 RE: Pinchbolt Steering Wheel - Ruairidh Dunford - 02-11-2017 Sounds perfect - if I leave now I should be in time for an early breakfast, leave the porch light on. |
