Vibration under load
1929 Chummy, 3 speed crash box, now experiencing harshness and vibration under load and feeling gear type vibration when just touching clutch pedal. One friend suggests flywheel loose on taper, any thoughts?
Crankshaft rear main bearing perhaps?
Check Fabric coupling first
Hello
Do you have the pin and block cardan joint at the rear of the propshaft. These can wear and cause vibration. Give the propshaft a good waggle side to side and up and down to check for play.
Adrian.
Clutch fingers set at different heights perhaps?
