Vibration under load - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Vibration under load (/showthread.php?tid=2970) |
Vibration under load - red29chummy - 19-06-2019 1929 Chummy, 3 speed crash box, now experiencing harshness and vibration under load and feeling gear type vibration when just touching clutch pedal. One friend suggests flywheel loose on taper, any thoughts? RE: Vibration under load - David Stepney - 19-06-2019 Crankshaft rear main bearing perhaps? RE: Vibration under load - Ken Morton - 19-06-2019 Check Fabric coupling first RE: Vibration under load - Adrian Payne - 20-06-2019 Hello Do you have the pin and block cardan joint at the rear of the propshaft. These can wear and cause vibration. Give the propshaft a good waggle side to side and up and down to check for play. Adrian. RE: Vibration under load - Terry McGrath - 20-06-2019 Clutch fingers set at different heights perhaps? |
