23-10-2017, 04:41 PM
What would be the modern equivalent of the oil/grease mix used in vintage chummy rear axles.?
Would D140 do ? or too thin!
Thanks
John W
Thanks
John W
Rear Axle Lubrication
Would D140 do ? or too thin! Thanks John W
23-10-2017, 04:52 PM
A similar thread is running below which contains the information you need.
I have found D140 and EP140 (Hipress) oils are perfectly suited for this application. EP140 (Hypoid) oil is not suitable for this application. I jack up the chassis, allowing the axle to hang down freely, and then fill until it just starts to come out of the filler hole, overfilling beyond this is not recommended and may result in oil contaminating the rear brake linings.
24-10-2017, 02:10 PM
williams
Morris do AG140. Straight Do not rule out their 'compounded' 460 bearing oils which are designed for yellow metals. |
