03-12-2018, 10:29 PM
Torque tube woes...
03-12-2018, 11:23 PM
(This post was last modified: 03-12-2018, 11:23 PM by Speedex750.)
Hi Nick,
It looks like an Austin part number but not one I recognise. If everything else has the right dimensions, can you machine down the taper end? Dave
03-12-2018, 11:43 PM
(03-12-2018, 11:23 PM)Speedex750 Wrote: Hi Nick, Hi Dave. I thought that too re the number, although I hadn't realised how clear it is in the photo... 1A7653 Unfortunately, everything is a little bit stretched. The reverse thread is a little further away from the pinion etc... so I don't think I can. I see there's another Speedex for sale in the association magazine. Did you manage to track down the Italian car and the Silverstone's new owner?
03-12-2018, 11:51 PM
Hi nick,
What is the gear ratio. If it's 5.125 to 1 and the pinion is longer than austin 7. Then it should be BIG 7. Tony.
03-12-2018, 11:56 PM
(This post was last modified: 04-12-2018, 12:25 AM by Nick Lettington.
Edit Reason: Credit where credit is due!
(03-12-2018, 11:51 PM)Tony Betts Wrote: Hi nick,Thanks Tony, that does make sense. Methinks I may be phoning you on the morrow... (Oh... Credit to the Association archive for the parts list) Ok... Anyone want a used big 7 cwp set? No use to me.
04-12-2018, 12:15 AM
(This post was last modified: 04-12-2018, 12:15 AM by Hedd_Jones.)
Keith Rawson used to fit big 7 axles complete as was off the car. He simply moved his ball forward on the chassis and sawed a bit out of his propshafts.
I wouldnt have thoight it beyond the wit of man to shorten a big 7 pinionshaft to fit. Perhaps by cutting & shutting the big 7 casing also? Though I do recall the casing is tapered?
04-12-2018, 12:29 AM
Thanks Hedd.
I'm wincing at the thought of it.
04-12-2018, 09:51 AM
With new A7 CWP's available off the shelf surely this might be better redirected to someone who may not be so happily placed.
04-12-2018, 02:58 PM
04-12-2018, 03:04 PM
Ha! Thanks David. that's the problem with reading upside down!
Still clueless. anyone got a better idea? |
