Torque tube woes... - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Torque tube woes... (/showthread.php?tid=2078) Pages:
1
2
Torque tube woes... - Nick Lettington - 03-12-2018 I thought I had a spare CWP set to assist in rebuilding my back axle, but as it turns out, the pinion shaft is about 2" longer than for a 7. Part number partially visible... Anyone know what they are for... And if so who might like them? RE: Torque tube woes... - Speedex750 - 03-12-2018 Hi Nick, It looks like an Austin part number but not one I recognise. If everything else has the right dimensions, can you machine down the taper end? Dave RE: Torque tube woes... - Nick Lettington - 03-12-2018 (03-12-2018, 11:23 PM)Speedex750 Wrote: Hi Nick, Hi Dave. I thought that too re the number, although I hadn't realised how clear it is in the photo... 1A7653 Unfortunately, everything is a little bit stretched. The reverse thread is a little further away from the pinion etc... so I don't think I can. I see there's another Speedex for sale in the association magazine. Did you manage to track down the Italian car and the Silverstone's new owner? RE: Torque tube woes... - Tony Betts - 03-12-2018 Hi nick, What is the gear ratio. If it's 5.125 to 1 and the pinion is longer than austin 7. Then it should be BIG 7. Tony. RE: Torque tube woes... - Nick Lettington - 03-12-2018 (03-12-2018, 11:51 PM)Tony Betts Wrote: Hi nick,Thanks Tony, that does make sense. Methinks I may be phoning you on the morrow... (Oh... Credit to the Association archive for the parts list) Ok... Anyone want a used big 7 cwp set? No use to me. RE: Torque tube woes... - Hedd_Jones - 04-12-2018 Keith Rawson used to fit big 7 axles complete as was off the car. He simply moved his ball forward on the chassis and sawed a bit out of his propshafts. I wouldnt have thoight it beyond the wit of man to shorten a big 7 pinionshaft to fit. Perhaps by cutting & shutting the big 7 casing also? Though I do recall the casing is tapered? RE: Torque tube woes... - Nick Lettington - 04-12-2018 Thanks Hedd. I'm wincing at the thought of it. RE: Torque tube woes... - Chris KC - 04-12-2018 With new A7 CWP's available off the shelf surely this might be better redirected to someone who may not be so happily placed. RE: Torque tube woes... - David.H - 04-12-2018 (04-12-2018, 09:51 AM)Chris KC Wrote: With new A7 CWP's available off the shelf surely this might be better redirected to someone who may not be so happily placed. Err............1A "7653" not 1A 7635? David RE: Torque tube woes... - Nick Lettington - 04-12-2018 Ha! Thanks David. that's the problem with reading upside down! Still clueless. anyone got a better idea? |
