29-08-2018, 03:58 PM
Please does anyone know the diameter of the standard flywheel across the starter ring teeth?
I am trying to improve performance on my sports engine by changing out the jets in the 30VE1 carb and also playing with the timing. I am wanting to work out where I am in degrees BTDC.
Original carb set up was Main - unknown(!) and Compensation 60, so not having a 90 I am trying an 85 main and a newer 60 compensation jet (haven't got a 55). Slow running stays the same at 60.
Original timing was set up as 1.25" BTDC fully advanced and I have subsequently advanced this a further 5°, so am tipping I'm now around 18° BTDC fully advanced, but want to check this.
Many thanks
Colin
Many thanks
Colin
