Flywheel Diameter - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Flywheel Diameter (/showthread.php?tid=1638) |
Flywheel Diameter - Colin Wilks - 29-08-2018 Please does anyone know the diameter of the standard flywheel across the starter ring teeth? I am trying to improve performance on my sports engine by changing out the jets in the 30VE1 carb and also playing with the timing. I am wanting to work out where I am in degrees BTDC. Original carb set up was Main - unknown(!) and Compensation 60, so not having a 90 I am trying an 85 main and a newer 60 compensation jet (haven't got a 55). Slow running stays the same at 60. Original timing was set up as 1.25" BTDC fully advanced and I have subsequently advanced this a further 5°, so am tipping I'm now around 18° BTDC fully advanced, but want to check this. Many thanks Colin RE: Flywheel Diameter - Terrytuned - 29-08-2018 Colin each tooth on the ring is spaced at 4.5 degrees. Terry. RE: Flywheel Diameter - Colin Wilks - 29-08-2018 (29-08-2018, 04:21 PM)Terrytuned Wrote: Colin each tooth on the ring is spaced at 4.5 degrees. Cheers Terry, very handy to know. Foolishly I measured the 1.25" on the flywheel, but didn't record the number of teeth, hence my query re the diameter so I can work backwards. RE: Flywheel Diameter - Colin Wilks - 29-08-2018 Think I've answered my own question. http://www.austin7.org/Data%20Pages/Tech%20Data/ states that 1 7/8" at flywheel = 20° From this the flywheel circumference is 33.75" and diameter is 10.74". My 1.25" BTDC at the flywheel is 13.3°, so 1 inch at the flywheel equals 10.7°. I really must get out more! RE: Flywheel Diameter - Zetomagneto - 29-08-2018 (29-08-2018, 04:21 PM)ETerrytuned Wrote: Colin each tooth on the ring is spaced at 4.5 degrees. Another good reply from Terry |
