Rear Axle Spacer / Nut
1931 rear axle pinion bearing distance piece - i.e. the smaller spacer which sits between the rear of the A/C pair and the big pinion support bearing. Or at least can someone tell me fairly accurately how long it was please? Mine is chewed up.
Also if anyone has a securing nut for the pinion shaft A/C bearing pair with a left hand thread I'm short of one.
Thanks
Chris
See my post on your thread on the main Forum, Chris.
