Rear Axle Spacer / Nut - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Rear Axle Spacer / Nut (/showthread.php?tid=1618) |
Rear Axle Spacer / Nut - Chris KC - 23-08-2018 1931 rear axle pinion bearing distance piece - i.e. the smaller spacer which sits between the rear of the A/C pair and the big pinion support bearing. Or at least can someone tell me fairly accurately how long it was please? Mine is chewed up. Also if anyone has a securing nut for the pinion shaft A/C bearing pair with a left hand thread I'm short of one. Thanks Chris RE: Rear Axle Spacer / Nut - Steve Jones - 24-08-2018 See my post on your thread on the main Forum, Chris. Steve |
