22-08-2018, 04:19 PM
Planning to fit a 1931 axle with 1" brake shoes to my Ulster rep which currently has semi-girlings.
I presume I should change the drums to earlier pattern - will everything else fit?
I don't want to convert the axle to semi-girling, but would consider an 'upgrade' to 1 ¼" shoes, in that case which other parts would I need to change?
Any advice appreciated. Fundamentally I'm not sure where that extra ¼" came from... I'd rather find out before I come to fit the axle on the car!
