Brake Swaps - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Brake Swaps (/showthread.php?tid=1615) |
Brake Swaps - Chris KC - 22-08-2018 Planning to fit a 1931 axle with 1" brake shoes to my Ulster rep which currently has semi-girlings. I presume I should change the drums to earlier pattern - will everything else fit? I don't want to convert the axle to semi-girling, but would consider an 'upgrade' to 1 ¼" shoes, in that case which other parts would I need to change? Any advice appreciated. Fundamentally I'm not sure where that extra ¼" came from... I'd rather find out before I come to fit the axle on the car! RE: Brake Swaps - Steve Jones - 22-08-2018 To change your new axle from 1" to 1.25" shoes you'll need to fit 1.25" pre-girling drums and 1.25" brake shoes. That's it. Steve RE: Brake Swaps - Chris KC - 22-08-2018 (22-08-2018, 04:36 PM)Steve Jones Wrote: To change your new axle from 1" to 1.25" shoes you'll need to fit 1.25" pre-girling drums and 1.25" brake shoes. That's it. Thanks Steve. The pivots are the same then? Logically then I suppose that I only need earlier drums to use the 1" shoes... RE: Brake Swaps - squeak - 22-08-2018 you can also use the cast iron girling drums. If you are using early closed center wheels the drums will need a light external skim to fit. regards russell RE: Brake Swaps - Chris KC - 22-08-2018 (22-08-2018, 10:17 PM)squeak Wrote: you can also use the cast iron girling drums. If you are using early closed center wheels the drums will need a light external skim to fit. regards russell Thanks Squeak. That sounds like the easiest option as I already have a nice set! Perhaps better to use 1 1/4" shoes in that case if only to wear the drums evenly. |
