Zenith 24T2
John, I believe you are correct and it is 1.5mm, you could solder up a 2mm one and re drill to the correct size.
(18-06-2018, 12:13 PM)Ian Williams Wrote: ......you could solder up a 2mm one and re drill to the correct size.
Thanks, Ian, perfect solution (but why didn't I think of that?!)
John
Colin - do you by any chance have the bit of the table that has the C.1372 Austin 7 variant on it?
I note its not in either of the ones above...
Hi
Not found a table.  However, the Dorset Austin Seven Club site quotes the following from an article (attributed to Tim Reynolds) on the 24T2, C.1372 that gives:
'The settings are as follows: Choke tube 14   Main Jet 75   Slow Running jet 50   Air Cap 150   Needle valve 1.5'
Hope this helps.
Regards,
Colin
