27-01-2025, 07:15 PM
I've returned my Chummy to 6V from the previous owner's 12V set up.
Everything is fine except for the clock which is 12V
Can I safely use one the variously advertised converters available from EBay etc or are there hidden problems with doing that. To avoid constant time resetting I'd plan to power the clock from a permanent (fused) battery connection.
