Car type: Austin 7 1927
I have seen them squeeze out, but never break up.
That is interesting, indeed rather worrying.Did the gasket come from a supplier of cherishness, or if you made it yourself, what spec silicone sheet did you use? What is also surprising is that the youthful Mr Dunford has time to look at the forum. Tis Hogmanay tomorrow, much preparation should be underway.
All prepped, days ago, Steve - a six course extravaganza.
Daisy will pipe us into 2025 ❤️
Just as well you are staying at home, weather forecast has caused Edinburgh to cancel everything except a candle lit service in St Giles.
30-12-2024, 08:02 PM
(This post was last modified: 30-12-2024, 08:03 PM by Ruairidh Dunford.)
Not everything, all the indoor events will go ahead.
It’s just the outdoor ones that have been cancelled. I’ve never seen the attraction of it, but many will be very disappointed, which is a shame.
