06-05-2020, 08:11 PM
Hi Forum members, what are the positives and negatives of silicone sump gaskets over the paper type.
Regards RPM
Regards RPM
SUMP SILICONE GASKET.
Regards RPM
06-05-2020, 08:18 PM
Providing all your studs are ok, it's a fit and forget option, and they dont leak. Fit them dry.
06-05-2020, 09:58 PM
I used one to cure a leaky sump joint. I also used a fibre washer on each of the bolts as well as the proper flange washers, result - an oil tight bottom end. They’re a bit more expensive but well worth itj
06-05-2020, 10:17 PM
As others have said, fit bone dry and use fibre washers.
Do not over tighten, just on the crush is best. Fit and forget, job’s a good-un.
06-05-2020, 10:31 PM
And there was me thinking that Seven engine oil leaks were 'de rigeur' and one of the many patents listed on the dash plate!
06-05-2020, 10:57 PM
And how, may I enquire, is one supposed to lubricate the underside of one's 7 and the top side of one's driveway if, by the use of these new-fangled silicone thingies, the oil is retained within the sump?
07-05-2020, 07:24 AM
Fear not, having carefully followed Rhuairidh's instructions on how to fit gasketry purchased from Jamie or made up from silicon sheets from a specialist catering supplier, the Ruby is as close to oiltight as possible. Austin Seven oiltightness is, however, a concept of its own, and whilst consumption is down to a pint of oil only for several hundred miles or so, a thin protective film is still applied to the underside. A huge improvement over a total loss early JAP, or indeed a Spamcan.
07-05-2020, 07:35 AM
Agree, even with oil tight sump, silicon gaskets elsewhere, oil appears - all that happens is the rate slows down quite a lot.
07-05-2020, 09:15 AM
Silicon sump gaskets. The best thing since sliced bread. No more nasty complaints from “Her who must be obeyed” about oil stains on the driveway. Since I fitted one I have got my stripes back.
John Mason
07-05-2020, 10:07 AM
Well, everyone that looks like a great big Yes and a thumbs up for silicone sump gaskets. Thank you so much. Rob
