10 hours ago
I tried to remove the spring pins on my A7. One side worked well, but the other side still does not move.
- I heated up the casing and cooled down the pin
- Used an extractor (large enough tube with big washer) to tear the pin out
- Used a hammer and a drift punch
but still there - any other ideas that might do the job ?
or is it now time for the cutting wheel ?
thanks, Oliver
thanks, Oliver
