Spring pin removal - cutting wheel ? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Spring pin removal - cutting wheel ? (/showthread.php?tid=9659) |
Spring pin removal - cutting wheel ? - mopetta - 22-10-2024 I tried to remove the spring pins on my A7. One side worked well, but the other side still does not move. - I heated up the casing and cooled down the pin - Used an extractor (large enough tube with big washer) to tear the pin out - Used a hammer and a drift punch but still there - any other ideas that might do the job ? or is it now time for the cutting wheel ? thanks, Oliver RE: Spring pin removal - cutting wheel ? - Ruairidh Dunford - 22-10-2024 Yes. RE: Spring pin removal - cutting wheel ? - Robert Foreman - 22-10-2024 The pin very likely is worn and has grooves in it. You may find jacking up the casing very slightly and using a big punch with a Big hammer shifts it. RE: Spring pin removal - cutting wheel ? - "Slack Alice" Simon - 22-10-2024 I had a similar problem on a Big Seven. I thought I would make a mess with a cutting wheel, and decided to try a hacksaw first. Thinking it would be hardened, and not cuttable, but ..... worth a try. To my surprise, the hacksaw worked. RE: Spring pin removal - cutting wheel ? - Hugh Barnes - 22-10-2024 I've found when fitting them, a pair of stilsons on the spring and twisting the spring a little can take the tension off the pin. Might be worth having a go like that whilst still giving the pin a good clout... |
