17-06-2024, 10:03 PM
I will check the fit of the VP69 shells in the housings tommorow and check the bore size with a vernier caliper.
Poorly Ruby
17-06-2024, 10:31 PM
A quick web search suggests they are Norton con-rod bearings, to suit a 1.75" shaft, so at least in the right ball park.
I found no data for the shaft and housing tolerances, but any decent recon shop (Ivor Searle have been helpful in the past) should be able to advise.
18-06-2024, 08:33 PM
The VP69 shells are a perfect fit in the housing the oil holes line up.
I measured the shells at 1.7490" with an expensive digital caliper. I measured one of my three bearing cranks at 1.7400" at the centre main. The other three bearing crank is 1.7245" at the centre main. I have done some more research and concur that the shells are Norton Con Rod Bearings. I suspect Stuart Rolt had something to do with these shells as he built a three bearing engine for my father in the late 1970s to early 1980s. I am pretty sure these were all extra parts collected just in case !!! |
