I have been using a weak solution of alloy wheel cleaner lately Ian but I am willing to try anything that others may think will work better. I need about 2 gallons to fill the U/S cleaner properly - what dilution do you recommend?
I am not saying it is any better than what you are using R, just that it has worked well for me
I understand - still experimenting with potions for the U/S bath - happy to try this. Will let you know the outcome.
Another fave potion of mine is marine clean, fantastic stuff, might be good in your U/S bath.
02-10-2017, 12:30 PM
(This post was last modified: 02-10-2017, 12:31 PM by Ruairidh Dunford.)
I have tried it but was disappointed when used in the U/S Cleaner - works very well with a stiff brush in weak warm solution.
Car type:
a bump for carb cleaning for those without ultrasonics! I'm more worried about internals so may try the meths. But does acid actually hurt mazac and brass, or just the oxidised surfaces we want to remove?
am I the only one concerned that the carbs on my cars are all dirtier than the one considered to need cleaning in this thread!
