I've never done rebores,Well ,only once to 60mm which lasted about 150 miles before the side fell out of one of the bores.But from the people who do they bore slightly undersize and get the cross hatch finish and size by honing.
I do sometimes still screwcut threads by hand as it's easier than trying to stop/reverse the motor each cut.A tip an ex Myford employee and friend gave me.
Cutting threads (imperial) on the Myford doesn't involve having to stop or reverse the motor, although to do it your lead screw has to be fitted with the thread indicator accessory. Cutting METRIC threads however does involve reversing or rewinding the lead screw manually because if you disengage you lose the correct mesh. This is due to metric thread gauges being different from imperial. HTH.
B
Ferzackerly what I meant to say mon pôte.
I wonder what bit of a Bristol plane those gears came from Ruairidh? Any slop in that bearing will produce a bore tapered the opposite way to normal.
That's an interesting piece and a really interesting story too. With the amount of company time and material that probably went into that "Homer" it might have have been cheaper for the company to have bought the bloke a brand new block, or at least let him rebore his own on one of the probably numerous horizontal boring machines that would have been in place at the factory back then.
The workshop where I spent a lot of my apprenticeship had the benefit of a manager who wouldn't have been able to interpret a drawing if his life depended on it, so some of the "industrial printer components" I was machining from EN8 billet came out remarkably like bits for the 500 Triumph motorbike I used for work before I bought my A7 Special.
Does the cone on the end locate the bottom of the bore as a guide ?
As noted above - it was last turned around 40 years ago Dave, but yes, I think you are quite correct.
The man who designed and made it was able to make it work successfully, which has always impressed me.
