My first lathe was a Drummond round-bed. It was very useful if limited.
I suppose you could re-bore an engine with almost anything that will spin a fly-cutter and progress on a lead screw...it's the setting-up of the block that would tricky and time consuming.
05-12-2018, 09:44 PM
(This post was last modified: 05-12-2018, 09:45 PM by Bob Culver.)
Around 1930 model Engineer carried many adverts for the round bed Drummond utilising photos of a quite large model working radial aero engine made entirely on it by ingeneous offsetting of the parts.
The M Type Drummond of the late 20s is a very usable lathe, much more so than a round bed. I lightened an Austin flywheel in one once. However the price difference between that and C type (or CUD) Boxford isn't great and if you can get a decent (ie not shagged out) Boxford you'll be much better off. Avoid the really cheap plain Boxfords without a leads crew - it'll frustrated you in time.
+1 for a BOXFORD Model AUD. There are also long bed varieties (39" long ??). They also come in Imperial or Metric lead screw versions. Mine is imperial and i use a 100/127 tooth conversion gear set for cutting metric threads. Although the AUD has a gear box, when cutting metric threads, you may need a couple of extra gears, but these appear on auction sites. IMPORTANT, when you buy a lathe, you need various chucks, tools, centres and centre drills etc. Often a second hand machine has these, whereas new ones may not have them. The attachments can add up to a hefty bill !
The standard Boxford comes with a plain cross slide (Without "T" slots) whereas the Myford has these as standard. Slotted cross slides are available for a Boxford and can be invaluable when doing "in-line boring" such as big ends on con rods etc. However, the Boxford was made industrial strength whereas the Myford in my opinion is Hobby Strength - (Wait for the shrapnel to start falling any time now !).
BobH - Boxford used for 50 years or so.
