08-07-2024, 03:13 PM
Rear axle noise
08-07-2024, 07:57 PM
Did a quick measurement and runout is between 3 to 5 thou. My dial guage reads in Millimeters but found a useful conversion
app online. Will (obvoiusly) do more checks once I have the crown wheel in position (maybe 2 weeks away if lucky). Suspicion only but wonder if someone stuck a screwdriver into the crown wheel to help with tightening the nut on the end of the torque tube. Suspicious but knowing the many 'bodges' found so far I would not be suprised. Diff casing now painted and looks much better. Have fitted the new diff seals as welll. Getting the 'C' ring back in was a fight but got there in the end. Tomorrow more checks on and around the diff-spring fixings and maybe climb under the car and check the propshaft and couplings up to the gearbox. |
