Missing chassis bolt ?
Managed to drill the first hole
A bit tricky to do with the tank in place
I needed to take out a short length of the chassis which looks like the support for the bumpers to get good access
I now need to identify what size bolts are needed and get hold of some if anyone can point me in the right direction
Thanks
5/16 BSF
Cheers Ruairidh
And use stainless bolts/washers with nyloc nuts unless you are wanting 100% originality.
Those particular bolts are captive in the chassis extensions, Dennis.
They’re just plain holes in my chassis Ruairid
Must be missing on my chassis ?
Stripped, more likely.
I see
